Results 1 to 16 of 16
Thread: injector help
    injector help
    I am learning to tune. I was just wondering how you get the lb/hr numbers for say ID1000. I read you have to multiply by 3600? Im stuck on understanding this formula. I have seen were FIC injectors gives you the lb/hr but Injector Dynamics gives you a different number. Thanks for any help guys.
    Jan 2018
    202
    just get the data directly from ID's website. works perfect every time
    Potential Tuner J1G5AW's Avatar
    Feb 2019
    New Jersey
    3
    there are only a few things you need to multiply in the id1000 data as the majority is simply plug and play (or copy and paste). I literally just did this last night for id1000's.
    Under scalars on the id1000 spreadsheet, everything that is lbm/sec needs to be converted to lbm/hr. easiest way is to simply multiply them by 3600. everything else just copy and paste.
    Jay
    2007 GT500
    ok Thanks Guys
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    Quote Originally Posted by J1G5AW View Post
    The current data from id's website uses the correct scalars
    Jan 2017
    48
    You can change the scalars in the tune. Just click on the scale.
    Feb 2019
    New Jersey
    3
    Quote Originally Posted by LastPlace View Post
    They are correct, I was just answering the the OP’s question as to the way he asked it.
    PMAS intake
    They are correct, I was just answering the the OP?s question as to the way he asked it.
    Hey man got a question about the info i got from PMAS for my air flow. the number of cells are not the same. i can show you pics if i nee to. thanks
    my HP tuner only has 40 Cells but the info from PMAS on has 38. here is the pics. What do i do about that? Thanks
    Make the extra cells the same as the last data point
    Mar 2010
    New Orleans, LA
    630
    horrible advice
    cross calculate the maf and approximate the unknowns then dial it in
    if you can't calculate between lbs/min and lbs/hr you prob should leave the tuning to the pro's
    decipha @ EFIDynoTuning
    http://www.efidynotuning.com/
    Oct 2016
    Poland
    1,741
    Quote Originally Posted by decipha View Post
    horrible advice
    It wasn't the best but a correct advice - you can do that and you only decrease your resolution without any significant side effects.
    Feb 2019
    New Jersey
    3
    Quote Originally Posted by Joey351sc View Post
    Screen shots a bit fuzzy and my tired eyes aren't helping, but I get what you're asking. And I agree with decipha on the cross calculating and approximating, it'll get you close and make adjustments from there.
    Jay
    2007 GT500
    Apr 2018
    605
    The spreadsheet has 39 values and you only need 40.
    Add to the top: 83.3 = 180.28
    Then go datalog and fine tune from there.
    Thanks for your help. I really appreciate it .
    Apr 2018
    605
    NP bud
