Results 1 to 4 of 4
Thread: 60E 1-2 shift pulls 20* timing, yet shows no TM active
    7,640
    Does this look weird, or normal?
    Stock 4L60E, mostly stock tune. I haven't messed with shift timing or pressures yet. I did try adding and subtracting TM (+/- about 40%), didn't notice any change. Both abuse mode tables are untouched. Yes, that horrible 1.0 second shift duration is on the to-do list.
    Timing goes from 18* to -1.x* during the shift while showing 'none' for both TM types. The advance & retard graphs don't change when the timing is being pulled. What's causing it?
    edit: 'Desired Trans Torque' drops from 12 to 0 when it happens, that's the only change I can see.
    13,565
    Timing removal of shift is normal, helps the transmission out.
    Going down to about zero is perfect if you ask me.
    7,640
    So... if Spark TM Type showed 'trans' in the list when the timing drops, I woulda said "Oh, good! TM is working." But it stays on 'none'. Am I logging the wrong thing?
    7,640
    Added a bunch more TM, reduced shift time, increased pressures a bit. Now it's able to complete the shift before the timing comes back up. Feels soo much better.
