Results 1 to 13 of 13
Thread: 2017 Mustang
    2017 Mustang
    Hi all , I have a few questions if I may , we had a 2107 550 in yesterday for some work and a dyno run , the figures the customer was expecting were well down.
    It has a cold air intake and x piece in the exhaust mods wise.
    It was running really rich on a stock tune which is where I reckon the power has gone.
    looking through the calibration "stoich value" is 14.08 , why would Ford do this ?? to keep engines super safe or for very hot dry states [ we have neither in the UK]
    Also we did the pulls in 4th gear , I can see from the calibration 5th gear has a ratio closest to 1:1 , does anyone know what gear they use on all the youtube vids .
    Thanks in advance for any help .
    Cheers Keith
    Jan 2017
    48
    I can answer a couple question maybe,,, The 14.08 is because most gas stations around the US is 10% ethanol.
    Most people do use 4th gear pulls.
    Oct 2016
    Poland
    1,761
    Quote Originally Posted by kevinhen View Post
    5%
    Best AFR for E10 would be 13.89.
    Jan 2017
    48
    5%
    Depends on where you get your information.
    Oct 2016
    Poland
    1,761
    Many different sources claiming something different, agreed. I remember seeing Ford claiming 14.09 for E5 but can't find it ATM:
    Mar 2019
    13
    Thanks guys , i completely ignored the fuel content you guys have , , the car is coming back in next week so will swap out the CAI for stock airbox and give it a run , then its fine tuning starting with the stoic value .
    Cheers keith
    Jan 2013
    Hawaii
    2,101
    In all Ford calibrations they use 9.0 for 100% ethanol and 14.64 for 100% gasoline.
    Using a direct relationship for E10 you would get 14.076 aka 14.08 or 14.1. Math for it would be (14.64-((14.64-9.0)*0.1))
    Stock calibration is perfectly capable of learning for E0-E15 with power loss that would be in the margin of error for most dynos, How rich are you seeing it go?
    Nov 2009
    All Around
    3,149
    the car will not run rich unless it went into over temp cat protection which there is a multiplier for that.
    in general if your fuel doesnt have Ethanol just change stoich to 14.64 and coyote engines like to be on the rich side low 12's
    Mar 2019
    13
    Quote Originally Posted by murfie View Post
    Hi murfie , its running 0.75 lambda to around 5500rpm then drops to 0.73 ,its running 0.84 at idle , i am going to data log it when it comes back in..
    Mar 2019
    13
    Quote Originally Posted by SultanHassanMasTuning View Post
    Thanks , thats something i will check on the data log ..
    Mar 2019
    13
    Just messaged the owner to check on the fuel he uses , and its just our regular RON 95 , do you guys use your Premium grade which is equivalent to our 97/8 RON.
    it will all help to find his missing ponies.
    Cheers Keith
    Jan 2017
    48
    I would address the .84 at Idle first. What are your STFT at idle. Have you done a MAF calibration?
    Also in the tune, does it command a .75 Lambda at WOT? and then above 5500 does it command a .73 lambda?
    That is very rich for a just a CAI and X pipe.
    On pump gas I would start around .83 command Lambda at WOT. That would be safe I think. I am sure others will chim in with something different.
    Apr 2018
    605
    I command .820 stock. I bet that's super safe, lol.
