Results 1 to 10 of 10
Thread: ly6 swap into a jeep tune chevk
    Mar 2019
    8
    just finished the swap and started the jeep but its throwing a p0171 and a p0174 this is the tune the swap company provided the engine runs and idles fine but very poor performance when i get on it
    info about engine everything internal is stock still using vvt
    map sensor has been changed to the newer style 2011 and newer
    mafs is the credit card style
    any input would be appreciated
    Have you tried running it in SD and see if it drives better? Do you know exactly what MAF they used and what map is being used (to ensure proper data is entered)?
    Mar 2019
    8
    Quote Originally Posted by RySmDPT14 View Post
    What do you mean by SD ?
    13,557
    Speed density.
    Are you positive you have zero vacuum leak and exhaust leaks?
    What's your fuel pressure?
    Potential Tuner Riptide9's Avatar
    May 2017
    Hillsboro, OR
    6
    I did a 6.0l L96 truck engine swap with the 6L80 trans in my 2011 Jeep JK over a year ago from RPMExtreme and this is my current tune for reference.
    Mar 2019
    8
    thank you for sharing
    Mar 2019
    8
    thank you for sharing that i used rpm kit as well just got screwed on the engine/tranny combo now i am stuck trying to tune the
    i used rpm extreme kit as well, did you use a ls3 card style maf ? just wondering so i can try and use your calibration
    also how do you like your transmission shifting points
    Mar 2019
    1
    Malek779, did you end up getting everything working?
    May 2017
    Hillsboro, OR
    6
    Yes, I am using the card style MAF and I did adjust my shift points from stock so they don't hit so hard under 60% throttle
    Mar 2019
    8
    sorry fro not replying, but yes got it all figured out
