Results 21 to 40 of 49
Thread: Question on Hp tuners DFCO / CFCO 2016 camaro 2SS M6. Need more burble / pops on dece
    Oct 2017
    Charlotte NC
    101
    Vlad95, you are in Basic view. Change to the Advance view by going to 'Edit->View-Advanced'.
    Sep 2019
    3
    Thank you very much. I was able to adjust the table and it definitely pops now. I have one question tho, right now it only pop once u get off throttle. Is there anything that could be adjusted that would allow it to pop just on decel like the 19s do. For example if you were to downshift.
    May 2003
    South FL
    1,376
    My 17 used to pop and bang real hard on downshifts without adjusting for it. Technically the same thing should work in the areas of downshifting but I haven't tested if it affects drive-ability. You will need to datalog the car when going through the downshifts and see what torque mangement advance is doing and reference against the cells in the areas of the same tables you adjusted. Also, if when you're downshifting the RPM's exceed the areas in the minimum spark table that you've adjusted, you will need to lower them for the higher RPM ranges too.
    I put my entire .12 and lower to 5 degrees once and the car sounded like a machine gun on decel and downshift at any RPM. It was so obnoxious I had to pull over and adjust the tune.
    [email protected]
    Owner/GM Calibrator
    Jun 2018
    43
    That?ll get you some attention. 😂
    Sep 2012
    Southern Germany
    65
    Is there anything like the GenIVs DFCO Delay to define a certain time when all DFCO conditions are met, before it will shut off the fuel?
    ____DH INDIVIDUAL____
    Hemi & LS Tuning in Europe
    www.dh-individual.com
  6. #26
    Potential Tuner TheRedFox's Avatar
    Oct 2019
    Germany, Near Stuttgart
    3
    Hi together! Im a totaly newby in using HPTuners and I hope you can help me to change my DFCO settings.
    I changed the Base and Long Term tabels in the minimum Spark Tab and now I dont know whats a good way to disable DFCO (disable over high ECT maybe, but I dont know if this is a good way).
    I have a 2017 Camaro V8 SS 1LT 6MT and want more or minimal the same pops and crackels on decel like when the engine is cold.
    Additionally I'd like to have some stronger pops and crackels only when I am in Trackmode, pushing a button / go into the Competition Mode. Is this possible?
    Thanks in advance for your help!
  7. #27
    May 2003
    South FL
    1,376
    Quote Originally Posted by TheRedFox View Post
    You need to leave DFCO enabled and at stock values. Also, you cant have factory cats on the car and expect much in the way of pops and crackles. #1) 4 cats will negate much of it. #2) The ceramic based cats cant take the abuse for too long and may fail/shatter etc. IF you want pops and bangs you need to lower the min value to 5 degrees every RPM you want them and then you can blend the values to increase as you dont need 5 degrees at high rpms for pops. I used to have mine scaled from 5 degrees at 1200 RPM to 12 degrees at 5000 RPM. But I also didn't have factory cats. That would have destroyed them.
    [email protected]
    Owner/GM Calibrator
  8. #28
    Oct 2019
    3
    Thank you very much!
  9. #29
    Nov 2019
    3
    I dont have a long term table, only a base table. I also have a 2010 Camaro which is a different generation. Is this why?
  10. #30
    Arizona
    247
    Select "Advanced View" in your editor and you'll see all tables
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
  11. #31
    May 2003
    South FL
    1,376
    For what its worth, GM has changed the Minimum Spark values for the 2019 model Z06 for more pops from factory. If anyone wants more burbles this is an easy copy paste. Obviously if you want more than this you can lower your minimum spark to 0 degrees and disable DFCO. That is where it gets really rowdy.
    [email protected]
    Owner/GM Calibrator
  12. #32
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    For what its worth, GM has changed the Minimum Spark values for the 2019 model Z06 for more pops from factory.....
    I mean.... is that REALLY WHY?
    Steve Williams
    TunedbyFrost.com
  13. #33
    Oct 2019
    3
    But can I use this on my 2017 SS 1LE ?
  14. #34
    May 2003
    South FL
    1,376
    Quote Originally Posted by Frost View Post
    Tadge himself didn't tell me so I guess it could not be the reason at all. But looking at the tunes from the 2019+ vs the older ones, there is almost no other changes. At least none that would affect engine operation. The purpose of the minimum spark from what I can tell in my experience is that it sets the floor for Torque Management Advance to use spark to reduce delivered torque. By lowering this table it allows TMA to pull values down into the range that start causing pop and burbles. If you're disputing my theory perhaps you could offer alternate views?
    Yes you should be able to without incident. If you find the car displays any drive-ability issues then I would just keep the stock values at the .20 and higher airmass and maybe blend them into the .16 and lower. .12 and lower are the hard decel areas and it blends into the .16 row at times so you might have to play with it.
    For what it's worth my .08-.16 rows are lower than this table in Minimum Base Spark but are exactly whats shows in the image for Long Term Minimum. I do it this way since I still have DFCO enabled. If you disable DFCO you can just make both tables the same. I get a good amount of nice pops and burbles before and during DFCO entry and then they stop when fuel is cut and the spark references the Long Term Minimum table. Perfect for how I want my Z06 to sound.
    [email protected]
    Owner/GM Calibrator
  15. #35
    Apr 2020
    3
    great info in this thread, thanks
  16. #36
    I get to many guys wanting me to do this to their car, and I just cant bring myself to do it lol
  17. #37
    Dec 2019
    DFW, TX
    124
    Quote Originally Posted by Phil'sC5Vette View Post
    I put the 2020 LT1 Camaro tables into my 18 2SS 1LE and when dfco is disabled, its just obnoxious and I feel like my cats are getting destroyed. Put those back to stock like a week later lol
  18. #38
    Tuner in Training Southwest Speed's Avatar
    Rio Rancho, NM
    41
    Quote Originally Posted by shaneb View Post
    i put the 2020 lt1 camaro tables into my 18 2ss 1le and when dfco is disabled, its just obnoxious and i feel like my cats are getting destroyed. Put those back to stock like a week later lol
    this.
    Southwest Speed LLC
    5116 Industrial Park Loop NE
    Rio Rancho, NM 87124
    505-554-9898
    https://www.facebook.com/southwestspeed/
    http://www.southwestspeed.net
  19. #39
    May 2003
    South FL
    1,376
    If you leave DFCO enabled in the tune it will only pop on transition into fuel cut. With the stock manifolds and exhaust it sounds good. If you add headers and a Catback I can see how it would be too much.
    [email protected]
    Owner/GM Calibrator
  20. #40
    311
    What is the reason for DFCO? Fuel mileage?
    I tried what you posted TriPinTaZ on my L86 with headers and no cats and DFCO enabled. But I didn't really here any difference. I'm going to take 5 more out of if and see what it sounds like. I would like to just get a-little gargle and pop.-
