Been tuning in AFR and my trims are good but I want to be able to tune in lambda.
Problem is I'm not 100% sure how to set it up. With the old versions you would set your offset along with commanded/14.7 against your WB. Here it's a little different.The properties are still the same but again....the how has me confused. Since this WB is already reporting lambda do I just plot it against the EQ ratio commanded or similar?
Would it be a matter of:
[6001]/14.xx]/[36.238] OR [36.238]/[68.238]
or something similar?
