Results 1 to 3 of 3
Thread: Running super rich after ID1300 injector swap, VE adjustments are not helping
    Feb 2016
    Orlando, FL
    83
    I swapped to ID1300 and entered the GM data from ID website. Now running super rich. See attached logs before and after.
    1st Flex fuel log with 42lb injectors.hpl - Before Swap
    1st Flex fuel log with ID1300 injectors.hpl - After Swap
    Tried adjusting VE table and the errors didn't get any better. See before change after change below:
    Steps where
    E36 2002 Taho Flex 2Bar_ID1300_SD_VE OL Tuning_Base.hpt - Flashed this tune
    VE Tuning Log2.hpl - Logged
    E36 2002 Taho Flex 2Bar_ID1300_SD_VE OL Tuning_log3.hpt - Copy pasted % multiply by then flashed tune
    VE Tuning Log_2-3_ve change.hpl - Logged
    It doesn't appear to me that anything got better or worse, and it pretty much stayed the same. I did interpolate and smooth.
    Any thoughts?
    Torque_Vector
    408ci stroker LS3 1998 BMW 323is - 490RWHP 466RWT in 100 degree weather
    260cc CNC Ported PRC heads, 11.25:1 Compression, 4" stroke, 242/250 .615/.615", Nick Williams 92mm TB, LS3 intake/fuel rails, FAST 39# INJ, 3" x-pipe dual exhaust
    Additions: ID1300 INJ, Flex Fuel Sensor, Aeromotive 5GPM variable speed Fuel Pump...
    Feb 2016
    Orlando, FL
    83
    I figured it out.... here is what I did
    changed Transient Fuel Qualifications
    Min Fuel Milligrams : from .041 to .010
    seemed to help a lot either that or I was smoothing the table too much
    Torque_Vector
    13,565
    The min fuel milligrams always has to be cut down on huge injectors, otherwise the injectors are going to spray too much fuel and it's usually at idle that it's the worst.
