Twin Turbo 2010 Escalade stage 3 cam twin 61/82r ID1050X SD tune.
What do I need to adjust for the axle management? 4th gear pull starts pulling timing around 9:28 mark on log. You can see it going into axle management for spark. the axles tq is already at like 7XXX which obviously not making that much. Was first drive after installing the injectors so I know I need to readjust VVE table for that. I have 3 lb spring in it but it was making much more than that as well.
TTOLsparkidleVEnotflashed8OLtablescoldstartsparkID1050XMAF.hpt
1050X1stDrive4thGearPull.hpl
