Results 1 to 10 of 10
Thread: Alcohol Content Sensor not reading
    May 2018
    12
    Hello all, recently i installed a ethanol content sensor and it doesn't seem to be reading in my scanner. i have an Flex enabled tune and the sensor seems to be wired correctly. i poured about 5-10 gallons of e85 in the tank and the scanner still displays 0.0% i've ran the vehicle for over an hour so the definitely is e85 at the sensor at this point. do i have the scanner set up incorrectly or is there something else in doing wrong?further fueling tuning 3 - 4L80E Segment swapped TWO.hptNo content.hpl
    13,565
    See if there is more than one ethanol or alcohol channel, could be the wrong one.
    May 2018
    12
    Seems to be the only one.
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    At one point, mine quit reporting on the scanner. I think I had to repoll to get it back. I think I removed it from channels, repolled, and then added it back to channels and it worked again. Hope that was it. It was a while back.
    2013 Silverado 5.3, 6L80k 8.8
    May 2018
    12
    Now it?s reading but I just added a a full tank of e85 and it won?t change from 37.6%, any ideas? I?m also getting a flexible fuel sensor circuit low code but all the wiring is showing continuity. When I measure pin 56 on the ecu (not coming from the sensor) it will show anywhere from 1 to 5 volts, should it be showing voltage at all? Kind of stumped here. Bad ecu maybe?? Bad sensor?
    May 2018
    12
    Quote Originally Posted by Lakegoat View Post
    I?ll give it a try, thanks!
    May 2018
    12
    No luck, still getting 37.6%
    May 2014
    2
    37.6 is the default for a failed sensor. I?ve been having problems with my gm sensors. I?ve been through 2 of them in less than 6months.
    May 2018
    12
    So it?s probably a bad sensor? That seems like the most likely problem I suppose
    May 2018
    12
    Got a new computer and a new sensor, still get a p0178 code. One thing I did notice was that I had the sensor wired wrong due to a misleading diagram. Could I have fried the sensors?
