wodin67 what did you change or fix or do to enable it? or how do I enable it?
Open your file in editor click compare>open compare>select (pe) file
compare>View compare log...
02 Silverado Z71 4x4 RCSB SS
It is not showing you changed anything!
Or am i doing something wrong
I figured it out i was clixking on the wrong tune lol
new pe log.hpl here is the log file from the short drive I just did with the corrections.
Pe is working .. Hows it feel ?
Bank one O2 is still not working early on..heater?.. if the wiring checks out id change it
Looks like there is a spark table pulling timing when pe is active...
still need that channel config (documents>HP tuners>VCM scanner>channel config) if nothing there open scanner click channels(left side screen)>save as...
channel config.Channels.xml here is the channel configuration. it pulls a lot harder now at wot it still lags some out of the hole but it picks up pretty quick. over all a huge difference in performance.
I will check out that 02 tonight after work I had the driverside head of lastweek fixing a broke bolt and the wires may have got burnt or something from the header not sure. I did get my wideband in yesterday gonna try to get it put in next week if I get a day off.
hey haven't messed with the truck in a while I have been working a lot. went for a cruise the other day and noticed it surging and spark knocking at idle under normal operating temp. then at wot it seems to be still running very rich. but it runs real strong at wot any tips or pointers to help fix these few things.
I also noticed some bag lag between shifts from 2 to 3 and 3 to 4 1to 2 seems ok it didn't do that with the original tune so these changes must have effected the trans tune. I know nothing about how to tune or tweek the trans. it has a built 4l80e trans with a trans go hd2 shiftkit and racing clutches and steels also has a circle d 3200 stall.
if pe is set to 1.19 all it does is a fuel multiplier. 1.19 would be 14.7 / 1.19 and would command a 12.35 afr
re-read your specs
as long as you can o2 working this should start up and idle it was initially rich
truck tune tweek Speed Density update.hpt
Remote Tuning [email protected]
