Hello everyone!
New to the forums and new to tuning. Not so new to cars and how they operate.
Need some advice and opinions before I blow the car up (mildly serious)
2000 Transam with an LS3, cam and bolt ons. 6 speed car.
Using MPVI2 PRO
Injector data all correct, timing tables off of a stock ls3 camaro, and I have tuned the VE tables in SD using STFT.
**No matter WHAT I DID, I can NOT get my STFT into perfect parameters. Most are +-2 or 3, a few 4s and 5s, and a SELDOM 6 or 7.
The cells that are higher than average looked like cells I didn't hit often (high load mid rpm for example). Every time I creeped in a cell for a few seconds it would creep closer to its target most of the time.
I got it VERY close, but can't get it perfect. This is all at operating temperature.
I said screw it and turned the maf back on, along with LTFT. Once I did this, I noticed my LTFT were in the 6 percent to 12 percent range depending on location. OK, running lean.
I made a maf histogram with LTFT+STFT data and tuned my maf frequencies. BOOM, -2 to 3 across the board on LTFT, Im sure I can tweak them but thought that was pretty fair.
Every time I adjusted my maf tables, my LTFT went down and the adjustments I needed to make in the histogram also went down. The car runs very well with a couple very mild hiccups that
are probably attributed to fueling. The car pops for a split second under high load low rpm in third and 4th gear. In those areas my fuel trims both show they are OK.
I have a wideband, but have not used it to tune anything yet. I hooked it up PROPERLY to the scanner, and the WB just bounces around like a kid on sugar. Its an AEM 30-4110
unit. I have read alot of others having this problem. Anybody have a work around for this??? Have it setup in AFR. Even in open loop it does the same thing. definitely a communication issue.
I did notice in the scanner even when my LTFT were adjusting fuel, my STFT were still showing values. They seemed to be zeroing in, maybe just not driving it far enough?
Hopefully this makes sense. I want to move on to tuning spark tables and WOT, but want to ultimately know if how I am fine tuning the fuel trims via MAF is sufficient?
