Ok guys took longer than id like to admit but i believe i figured this injection timing stuff out.
Have a couple more questions.
Using Eds tutorial i graphed a few scenarios.
In his tutorial he explains limiting WOT SOIT to around
-100? to keep the next injection cycle out of the last cycle.
In my case that would result in larger inectors to limit the pulswidth and injection duration.
My question is what would happen if i did not change injectors?
What the heck do you do with the makeup table?
And the normal table ive been modifying the operating temp ranges (140? and up). Do i modify the lower temp ranges with the same calculated differences.
