Results 1 to 9 of 9
Thread: E40 ECM fan won't go off unless the speed over 15MPH Help please
    Sep 2016
    7
    hello there
    im having a problem with the fan wont turn off unless i turn off the car of move over 15MPH
    im tuning E40 ECM
    any help would be appreciated
    Tuner 5ft24's Avatar
    Mar 2018
    Sedro Woolley, Washington
    110
    With the temp vs state, do you have one value set to 25? If not, it will run all the time as it sees a request for the fans at all times
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    FIC1000 shorty Injectors
    DW300C Fuel pump
    UPP GTO Auxiliary fuel system
    BoostDistrict LSA Conversion
    BTR Stage 3 PDS Torque cam and kit
    Kooks Longtube headers with High Flow Cat mids
    BoostDistrict LSA CAI with LS7 MAF module
    Mickey Mouse Catch Can
    Hinson 1/2" lowered Engine Mounts
    Magnaflow 3" Cat Back Competition Exhaust
    PLX DM-6 Wideband
    Turbo Technologies Full Flex fuel Tune
    Sep 2016
    7
    Quote Originally Posted by 5ft24 View Post
    blazer 2005 v8 5.3 fan.hpt
    this is the file , i already have set some values to 0
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    This
    2013 Silverado 5.3, 6L80k 8.8
    Sep 2016
    7
    I gave it a try but no luck... Just read some threads and I found out that on E40&E67 the fan won't turn off unless the speed of the car above 15MPH and that due some GMPP rule unfortunately Hptuners has no solution for this
    Thanks very much for the support
    Mar 2018
    110
    I have no issues with mine staying on. It cycles with temp as it should, even after flashing with HPTuners and lowering fan set points. I'll post a screenshot of the appropriate tables later today
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
    Sep 2016
    7
    Them I'm assuming there could be a later calibration which could solve the problem. I will try update the calibration but first I will have a look on your file tables
    Thanks in advance
    Mar 2018
    110
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
    Sep 2016
    7
    I did try those tables but again no luck,, it is nice to see tuner with 3d printing experience ��
    Thanks for the support
