Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Total Newb Here, Duh...Check This Out Please
    Jun 2011
    MARKHAM,ON
    77
    Still showing misfires. I temporarily swapped in 4 of my LS1 coils on bank 1 and misfires and high fuel trims still present.
    Injectors.have about 130K miles, so I'm told. I should probably swap those out for sure.
    After all that, victory! I had small gaps in my test pipes. I seen carbon trails so I used foil tape to close the gaps and fuel trims all good now.
    13,559
    Sometimes you have to re-poll for supported parameters to find the misfire channels.
    And exhaust leaks are a killer with fuel trims, they will suck in extra air and skew the numbers big time.
    Jun 2011
    MARKHAM,ON
    77
    Thanks.
    Repoll?
    How do I do that?
    Yeah, I was surprised that air can go backwards up the tube thru a small gap. Logic tells one that pressure keeps air out.
    Jun 2011
    MARKHAM,ON
    77
    Thanks again.
    I re-polled and got the misfire channels.
    I have a lot of misfires on #1 but the engine is on a stand without full exhaust so install will be next.
    I just figured out how to watch the logs. This is a really excellent device.
    Testing to attach file..................
