First time messing with one of these and already lost. This thing was already tuned and it seems like trash. MAF has two sensors? I tried logging both but only one registers anything. The one that is registering bounces down to zero hertz while driving and then back. its real spastic. Also this thing has no timing when just cruising it has no power. It just seems to fall on face every gear change. Another thing is the idle I see it drops alot on change from P to D which I would adjust airflow for this normally but there is Minimum Airflow table/Base Running Airflow tables that are gear driven...they just seem to be ECT driven with run time. Thanks in advance.
MAFonly.hpt
1st drive.hpl
