Collecting readings almost immediately after collector. Can't get the gauge to read right.
Even at WOT under PE the gauge hovered around 14.6. Obviously not safe. BUT my LTFT were pulling OUT fuel throughout my whole table. I have my open loop EQ ratios set up right.
I picked up no KR under any circumstance, except for about 1.5 degrees around 80 KPA at 1600 (must have stabbed the gas).
So I know no detonation, and the car definitely smells like fuel. What gives? I think its a bad sensor. Very aggravating. Brand new AEM 30-4110 kit with a Bosch 4.9 LSU.
I even set up my PE settings to engage PE at 15+ map and anything over 20% tps. Same thing. I KNOW it would be running PIG rich around those areas.
I know it doesn't mean much but when going into PE 02s are 900 and 951 MV respectively.
