Results 1 to 6 of 6
Thread: E38 L99 6L80E Camaro 2010 in 3gen Trans Am
    Mar 2019
    2
    I am asking for your understanding.
    I'm learning...
    - O2 rear delete
    - Vats disable.
    - No BCM in my application.
    - Gas pedal comes from corvette c6 on L99.
    The engine goes off immediately after the start.
    See the video from my scanner.
    https://youtu.be/Mq77c5Grw6U
    Injection does not show work.
    What could be the reason?
    Probably some cable I forgot to connect well.
    Explain how to a child
    0x7E8: P0120 - Throttle / Pedal Position Sensor A Circuit (Permanent)
    0x7E8: P0122 - Throttle / Pedal Position Sensor A Circuit Low (Pending, Current, Old, Permanent)
    0x7E8: P0223 - Throttle / Pedal Position Sensor / Switch B Circuit High (Pending, Current, Old, Permanent)
    0x7E8: P0532 - A / C Refrigerant Pressure Sensor A Circuit Low (Current, Old, History)
    0x7E8: P0557 - Brake Booster Pressure Sensor Circuit Low (Pending, Current, History)
    0x7E8: P0606 - ECM / PCM Processor (Permanent)
    0x7E8: P0615 - Starter Relay Circuit (History)
    0x7E8: P2068 (Pending, Old)
    0x7E8: U0101 - Lost Communication with TCM (Pending)
    0x7E8: U0109 - Lost Communication With Fuel Pump Control Module (Pending)
    0x7E8: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module (Old)
    0x7E8: U0140 - Lost Communication With Body Control Module (Pending)
    Mar 2019
    1
    I am having the same issue right now. My L99 and trans came from a 2010 Camaro. I read a lot of posts about how to remove the VATS and have done them all. I was finally able to get it to start when I Disabled the Starter Diag. in the OS but it just dies right after cranking is over. It seems like the VATS is not being disabled fully.
    I am running the New MVPI2 that I upgraded to from the MVPI1. I have the latest software from the site.
    I have even tried to enable the VATS again and then disable it again.
    I am at a loss myself.
    My next step if I cannot get any other ideas, is to send my ECU out to be looked at.
    I forgot to mention, I am only getting one DTS now. P0606.
    Feb 2019
    6
    Hi there,
    I'm having the same issue with mine,
    although mine is an l77 with 6l80e, with e38 ecu.
    Did you end up working out what the issues was ?
    thansk
    regards
    Paul
    Dec 2018
    2
    Quote Originally Posted by paubert78 View Post
    Hi there,
    thansk
    regards
    Paul
    Dec 2018
    2
    Hi there,
    thansk
    regards
    Paul
    Change fuel pump settings
