Results 1 to 20 of 40
Thread: Parameter Templates now in VCM Editor 4.3.431+ (NEED BETA TESTING FEEDBACK)
    Sep 2002
    Chicago, IL
    6,395
    If you are constantly applying the same set of parameters across multiple tunes, you can now use our Templates feature to create a template once, and then easily apply it to future tunes.
    Please see the documentation here:
    http://www.hptuners.com/help/vcm-edi...templates.html
    This feature is available in VCM Editor 4.3.431+.
    This feature does need testing.
    - Please verify that the values you define are being applied to the tune correctly.
    If you find an issue please report it in this thread.
    - Please include the necessary files and steps so that we may duplicate the issue.
    User Defined Parameters are not available yet. That is a work in progress.
    We got this guy Not Sure, ...
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    That's great!
    I requested this feature long ago, happy to hear it's becoming a reality.
    Regards
    9 sec Montecarlo SS
    Jan 2004
    Columbus, Ohio
    213
    Very nice!
    2022 Cadillac CT5-V Blackwing (733 whp)
    2022 Cadillac CT4-V Blackwing (716 whp), 10.750 @ 134.77 mph
    2016 Cadillac ATS-Vs (eleven ATS-Vs in the 9s)
    2008 Pontiac G8 (first G8 in the 10s), 10.727 @ 129.87 mph
    2000 Bonneville SSEi (first 3800 Bonneville in the 10s), 10.711 @ 125.71 mph
    1999 Grand Prix GT (first 3800 FWD in the 8s), 8.902 @ 154.90 mph
    1998 Firebird (first 3800 RWD in the 8s), 843 whp, 8.991 @ 152.12 mph
    1998 Grand Prix GTP (first 3800 FWD in the 10s), 9.499 @ 145.13 mph
    Keith,
    I'm not having any luck with this... How do we create a template?
    when i open the template applicator I can only click open template.
    EDIT::: nevermind I found it.
    Question is this different than doing a compare and copy? I see the usefulness it's just going to take some time to setup.
    One thing that would be extremely helpful is and export and import function to get the tables out in to excel. I have have sever excel macro programs I wrote to do things like resale the timing tables and torque models as well as map builders for e85. If I could export and thing import say all the borderline tables at once that would be great.
    Quote Originally Posted by Keith@HPTuners View Post
    So I found a major problem. Row and column labels do no pull into the template. They come in as defaults, this is no good for the Ecoboost!
    Sep 2002
    Chicago, IL
    6,395
    The row and column values should pull in.
    The labels aren't there because the "Table Template" you're creating is simply a set of numbers of a given measure/unit. Actual row/column labels have no meaning.
    As long as the target tune you're copying to has the same measures and sizes, the template applicator will apply the table successfully.
    That's the problem, they are not pulling into the template and I cannot modify the value in the template.
    Tuner in Training bluessmax's Avatar
    Feb 2011
    Lake Charles, La
    19
    Thanks guys - this will certainly save us valuable time!
    Infatuated by advancing acceleration in one hell of an aggressive manner.
    PPEI.com
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by zfgracing View Post
    Please attach a tune and step by step (click by click) steps so we can reproduce the issue.
    Can you shoot me an email? I just created a template from a tune and applied that template to the stock file. It didn't work at all.
    [email protected]
    Sep 2002
    Chicago, IL
    6,395
    Please open up a support ticket and we can look at it.
    https://support.hptuners.com/index.php?/Tickets/Submit
    Everything worked except for the DTCs.
    Sep 2002
    Chicago, IL
    6,395
    Quote Originally Posted by Zero4488 View Post
    Can you elaborate?
    Can you post a tune and step by step instructions so we can reproduce the issue you're seeing?
    DTC's should be working.
    Oct 2016
    Poland
    1,750
    WOW! I always wanted a feature like this! Thanks guys! Works great!
    Can you elaborate?
    Literally followed the instructions posted and the only thing that failed was the DTC list. I will get the tune posted up as soon as I have a second.
    Sep 2002
    Chicago, IL
    6,395
    I just tested every parameter type on an ecoboost and they applied correctly.
    I just tried again and the template i created from a tune will not apply back to the stock I will email support with you copied.
    Scratch that I screwed up. the key is to open the stock and compare the tune to create the template....
    Aug 2014
    Central, LA
    737
    This is great! Will it be possible to remove items from existing templates?
    For instance if I wanted to "import parameter differences" and then just remove a few items that were imported to make slightly different versions of the template?
    Being able to uncheck which ones to apply takes care of this need but I'm just curious.
    Sep 2002
    Chicago, IL
    6,395
    Removing individual parameters is already supported, and documented in the help file link.
