LE5 Stand alone throttle issue
Whats up fellas need some help. I build harness's for buggies, circle track guys and what ever else people want to shove a eco in.
So i just started building the le5 harness with the e67 ecu, i have everything built ecu flashed with a basic tune in it nothing fancy. Anyway i went to do a bench test to make sure the tb works. Well it does not. I have checked and double checked my wiring and its all correct. still nothing
Does it need to all be hooked up to a motor to work the TB?
As of now i have it hooked up on my bench with a pedal and a tb, those are the only two plugs that are hooked up plus the power for the fuse box,
My fuse/relay box is a five wire hook up. Ground, key power, constant power, fan, fuel pumps.
I have searched theads goodle and just cant seem to find a answer. I will up load the tune file for you all to take a look at.
Thanks in advance
jacob holder 2.4.hpt
If you have everything connected on the bench ,your throttle should work. Steve
I have Key power, constant power , ground hooked up , my pedal is plugged in along with a tb. none of the other sensor plugs are pluged in should i be able to work the tb at this point?
Yes, see #2 above. You must be missing something in the wiring. Does the TB test cycle happen when you key on?. Steve
NO Its not cycling when you power it on.I have checked to wires a couple of time checked my pinout and i am not seeing that i have missed anything. Going to go over it again
Pm me and I will help you sort it out. Steve
