Results 1 to 10 of 10
Thread: Misfire counter not working
    Dec 2012
    Arkansas
    22
    Looking for a clue guys. Mpvi2 , vcm scanner when logging the misfire counter is staying on zero therefore I believe I can't see any misfires (which I believe I have). I've set it up with current and history pids. As well as misfire cycle pid. (5.7 vortec 0411 pcm) I'm Almost positive it has the capabilities as my tuner guy pointed a few misfires out last year while tuning it before I got my own hp.
    Sep 2017
    736
    Quote Originally Posted by jefost8 View Post
    Mine is the same with ny 0411 swapped lt1. Just figured i missed somthing but havent gotten around to it.
    Advanced Tuner Obsolete489's Avatar
    Feb 2017
    Yankton, SD
    299
    Did you mess with any of the misfire tables? Post a tune?
    2000 K2500 - 489 CI Vortec w/ comp XE270 cam - 0411 swap and rear mount turbo
    1972 M35a2
    2011 LML Duramax
    Dec 2012
    Arkansas
    22
    here is the tune file
    Dec 2012
    Arkansas
    22
    I know this tune has had misfires read with a mpvi1 last year.
    Feb 2017
    Yankton, SD
    299
    Okay, I just wanted to check that the tables were intact.. it appears that they are. And if it worked on mpvi1 then i guess the change is awful suspect.. Have you emailed support?
    1972 M35a2
    2011 LML Duramax
    Dec 2012
    Arkansas
    22
    yes they suggested loading a different tune. they suggested if i had a stock tune to try it. i didn't have one so i found one in the repository and apparently had it open in editor (which i thought was ok) and purchased 2 credits then went to write it to my pcm and it said my pcm wasn't licensed. does this sound right? will i have to read my pcm and have it open when buying the license?
    Feb 2017
    Yankton, SD
    299
    Sucks you licensed that tune.. What I'd have done is license the tune pulled off your computer, then use the compare function to change whats needed.
    1972 M35a2
    2011 LML Duramax
    Dec 2012
    Arkansas
    22
    Quote Originally Posted by Obsolete489 View Post
    I wonder if it's inherent to the 0411/ l31 (5.7 vortec) pairing? With the compare feature I wouldve only gotten calibrations I think. Wouldn't I be looking more towards the operating system....not sure if I'm barking up the right tree here
    Feb 2017
    Yankton, SD
    299
    Maybe I'm wrong here, I haven't tried it, but i think you can change OS with the segment swapper?
    1972 M35a2
    2011 LML Duramax
