Results 1 to 3 of 3
Thread: E40 flex spark multiplier.
    Tuner 5ft24's Avatar
    Mar 2018
    Sedro Woolley, Washington
    110
    Was tweaking my spark tables for Flex on my 2006 GTO, and noticed the PE/COT spark advance Multiplier vs fuel comp is all zeroes. does this table need populated?
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    FIC1000 shorty Injectors
    DW300C Fuel pump
    UPP GTO Auxiliary fuel system
    BoostDistrict LSA Conversion
    BTR Stage 3 PDS Torque cam and kit
    Kooks Longtube headers with High Flow Cat mids
    BoostDistrict LSA CAI with LS7 MAF module
    Mickey Mouse Catch Can
    Hinson 1/2" lowered Engine Mounts
    Magnaflow 3" Cat Back Competition Exhaust
    PLX DM-6 Wideband
    Turbo Technologies Full Flex fuel Tune
    Jan 2014
    Australia
    1,977
    if u are using the pe/cot multiplier table then yes it will need to be populated so as it works with varying ethanol % or if u dont use that table to modify spark then its not needed
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,456
    Here is mine. I have cot off but there is still pe.
    2013 Silverado 5.3, 6L80k 8.8
