Results 1 to 10 of 10
Thread: Starts then stalls
    Jun 2017
    36
    Angry Starts then stalls
    New LS2 swap. I deleted the Vats but the engine starts then stalls out right away. I installed another E40 and it stays running with that tune but I need to put it back were it came from.
    Nov 2009
    All Around
    3,149
    what are the parts installed
    please post the current tune
    7,637
    Read & save the tune from the working ECM, load it as a compare file with your non-working ECM.
    Jun 2017
    36
    Current configuration
    This is the base read with the VATS disabled.
    Nov 2009
    All Around
    3,149
    try this, maybe you have an issue with your Maf placement
    05 GTO Base Configuration SD Mode.hpt
    DID you do write entire with vats delete .Must on gen 4 not like gen 3 .
    learning
    Jun 2017
    36
    I think I did the complete rewrite but I'll try again. Thanks
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    Do you have a maf on this swap? How about cats? Aftermarket cam?
    2013 Silverado 5.3, 6L80k 8.8
    Jun 2017
    36
    Yes, the MAF is inplace but no CATS. Not sure about the cam. O2's aren't hooked up yet but that shouldn't be causing the start then stall problem. As I said earlier, it runs with another E40 hooked up.
    Jul 2012
    Florida
    1,459
    Make your base idle spark 16 instead of 13 and add 3.00 to your base running airflow--airflow final minimum chart, from 250 to 2000 rpm and see if it will start. Check to see that you have the correct map sensor that your tune calls for (GM 1 bar). At key on, engine off--what does your map sensor read??
