Results 1 to 4 of 4
Thread: Hellcat low boost
    Mar 2019
    4
    Hellcat low boost
    hi Guys,
    i have a Ram 1500 that i fitted a Hellcat motor to, the first 9000 miles the Ram pulled like a beast.
    but now it feels like the power has disappeared.
    i did a log and see that i am only getting round 5-6 PSI boost, what can the problem be?
    the belt is not slipping, everything on the engine is still stock.
    How much boost does it normally produce? I didn't see any knock from bad fuel. Did you happen to pin the balancer to prevent it from spinning on the crank? Im sure its something else but just in case.
    Mar 2019
    4
    Quote Originally Posted by orrwhat View Post
    i will check that, on the logs i run round the 18psi on 3000 rpm, then it starts to fall off
    Nov 2009
    All Around
    3,149
    stock engines run around 11/12 psi depending on elevation
    it will never hit 18 psi unless you have the smallest supercharger pulley and overdrive pulley
