Results 1 to 6 of 6
Thread: E92 Two Step Launch Control
    Jan 2004
    Columbus, Ohio
    213
    Has anyone had success adding a two step rev limiter to the E92 ECM? Forum search doesn't really bring up much content from the current decade.
    If you've pulled this off, can you share the best balance of hardware and tuning changes? Planning to work on this, and was hoping to not have to re-invent the wheel.
    Thanks in advance!
    2022 Cadillac CT5-V Blackwing (733 whp)
    2022 Cadillac CT4-V Blackwing (716 whp), 10.750 @ 134.77 mph
    2016 Cadillac ATS-Vs (eleven ATS-Vs in the 9s)
    2008 Pontiac G8 (first G8 in the 10s), 10.727 @ 129.87 mph
    2000 Bonneville SSEi (first 3800 Bonneville in the 10s), 10.711 @ 125.71 mph
    1999 Grand Prix GT (first 3800 FWD in the 8s), 8.902 @ 154.90 mph
    1998 Firebird (first 3800 RWD in the 8s), 843 whp, 8.991 @ 152.12 mph
    1998 Grand Prix GTP (first 3800 FWD in the 10s), 9.499 @ 145.13 mph
    Nov 2009
    All Around
    3,149
    isnt there a box and its wired to the coils i forget which company
    Tuner in Training hitmix300's Avatar
    Jun 2015
    detroit
    20
    Quote Originally Posted by SultanHassanMasTuning View Post
    yes its lingenfelter part "lnc-2014"
    OP i dont think you can change the factory two step as its not in the pcm from my understanding. i think i was told it was bcm or ccm, etc.
    2016 GenV 2SS twin turbo @20psi
    Jan 2019
    11
    https://www.holley.com/products/igni...ls/parts/87331
    I have mine connected to my brake light switch on automatic. You can also connect it to clutch switch for manual.
    Jan 2004
    Columbus, Ohio
    213
    Quote Originally Posted by KemahGT View Post
    That looks great. Thanks for sharing!
    Have you used this with an E92 ECM? And did you have to do anything special to keep the ECM from not being happy with the engine speed not doing what was expected?
    Jan 2019
    11
    I must correct myself. I had a similar 2-Step connected on an S197 Mustang to the brake light switch as an adjustable launch control. It worked great on the Ford.
    My intention is to try the same on my C7 auto. I have only used it to act as a rev limiter to kick in slightly before the E92 limiter on the stock tune. When manually shifting it would hit the MSD limit before the E92 limit. If I was late shifting the engine would “stutter” rather than “fall on its face” before grabbing a late shift.
    I’ll report back after getting it wired to the brake light switch. I have deleted DoD entirely and do not plan to manually shift very much in the future.
