Hey guys i have a 2005 gto with E40 ecu. I am having a problem when i try and copy and paste data. when i copy the injector data from fuel injector clinic then paste to hp tuners the data is not the same. It is off very slightly. Also i am trying to run 2 bar speed density and when i copy the 105kpa table from PE over to the BE table the numbers aren't the same also. Has anyone seen this before? Is this normal. Thanks
