Results 1 to 12 of 12
Thread: E85 tuning 98 5.0 supercharged f150
    Nov 2018
    Georgia
    81
    What are the main tables of tuning for e85?
    Advanced Tuner LastPlace's Avatar
    Jul 2016
    613
    post your tune file so we can see whats available for as 1998 model
    Jan 2013
    Hawaii
    2,101
    By the user name, I think he meant 18.
    the main table would be the stoich AFR [ECM]2300. Unless you are talking about flex fuel.
    Oct 2016
    Poland
    1,712
    Quote Originally Posted by murfie View Post
    the main table would be the stoich table. Unless you are talking about flex fuel.
    If you change the last row in Base Cold fuel table that would be your stoich from now even when fully warmed up. This table somehow over-rides the main stoich value.
    Nov 2018
    Georgia
    81
    Sorry guys 2018
    Nov 2018
    Georgia
    81
    thanks got that set at 14.7 what im trying to change is afr at wot full boost (13 psi) tps 100%
    data shows .70 lambda (10.3) i would like to lean that point more towards 0.85 (12.5).
    i just cant seem to find the correct tables to change. the roush tune im running has PE delayed/off to 120 seconds. i have a 2018 5.0 f150 and installed the roush
    supercharger with tune. LEARNING using hp tuners. thanks so much
    Nov 2018
    Georgia
    81
    looking at this its at stoich thanks read my reply see what you think and not sure how to upload my tune and data
    Nov 2018
    Georgia
    81
    how can i attach my tune to this thread?
    Jul 2016
    613
    Quote Originally Posted by 18f1505.0roush View Post
    The "go advanced" button, then use the "Manage Attachments" button.
    Nov 2018
    Georgia
    81
    I think I figured it out my MAP max before combustion stability is set to allowing CS to take over at low boost
    Ecm 44821. So changed Cs to where I want to be. (ecm 33784)
    Data log shows lambda as the Cs tables are written.
    I will load the new tune and update thanks
    Nov 2018
    Georgia
    81
    Made a few short rolling test hits today for data Lambda is exactly where i wanted it .85 (12.5) afr. so I will try to lay down some actual short runs by the weekend.
    13 PSI
    .85 lambda
    100% TPS
    10 DEGREE TIMING
    93 OCTANE
    WHAT DO YOU THINK? POSSIBLE MORE TIMMING?
