Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: something wierd and not good
  1. #21
    Nov 2004
    231
    it looks like you are going into pe after about 4sec of WOT. maybe there is some delay value somewhere??
    04 VY Commodore ute M6 ls1, 918 valve springs, TR6 plugs, genttrbb twin turbo kit, 60lb seimiens injectors, Bosh 044 fuel pump, SX fuel reg, PLX wideband,Full Castle Hill Exhaust with 2 1/2in dump pipes, 4in cats into twin 3in cat back (no merge), Ripshift, oz700 clutch and 3.73 diff gears
  2. #22
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,260
    yeah, most trucks have a delay in seconds...usually the RPM enable will cancel that out...usually.
  3. #23
    Nov 2004
    231
    also i noticed that you have STFT enabled in open loop. have you tried it with this disabled??
    When you go WOT your LTFT do lock at 0 and only your STFT have values so it does looks like you are going into open loop .....but not??? im confused
  4. #24
    Feb 2006
    18
    My 05 doesn't have a problem going into PE. I just checked today and I from a dead stop, PE will kick in at 1061 RPM. Enable torque is set at factory 100% and the delay RPM set to 1500.
    2005 1500 CC Z71
    1997 Pontiac Grand Prix
  5. #25
    Feb 2006
    18
    Here's a screen shot of my log.
    2005 1500 CC Z71
  6. #26
    Tuner 1slowsilverado's Avatar
    Oct 2005
    Daytona Beach
    104
    Most 05+ trucks (not all) have this problem. The fix has allways been to set the Enable Torque to 0 for all the trucks that wont enter PE. Your log file with Enable Torque at 50% seems to be just that.... Post up the fix when you figure it out.
  7. #27
    Advanced Tuner gman4dx266's Avatar
    Jun 2006
    Cape Coral, FL
    860
    hmm...possibly something to do with electronic throttle? I have an 06 and everything so far has been just peachy, especially as far as PE goes.
  8. #28
    Dec 2005
    214
    put it at 0 and same thing.
  9. #29
    Dec 2006
    Birmingham, Alabama
    156
    I had the same problem with a 2006 3500. Would not go into open loop.
    Setting the Enable Torque to 0 fixed it.
    FUEL - Power Enrich - ENABLE - Enable torque
