Results 1 to 3 of 3
Thread: Larger MAF
    Mar 2019
    Enumclaw Washington
    8
    Larger MAF
    Just wondering if I would need to do any reprogramming to go from a 12574383 MAF to a larger 25168491 MAF? This is a stock 2004 6.0L. I made my custom 4" intake tube with cold air intake before I measured the MAF that came with the engine. Would like to use the larger one as it would be a better fit. The small one is about 85mm. The larger one is about 92mm.
    Thanks.
    13,564
    Yes, you must re-calibrate the airflow model.
    Mar 2019
    Enumclaw Washington
    8
    Cool, thanks for your help.
