Originally Posted by
DHC
Some of the data needed for the injectors is missing. I would spend the money and get a set from ID or FIC, at least the $500 spent will get you proper data and good injectors. Crappy parts and data give crappy results.
Once injectors are handled get a AEM WBO2 setup and get that in the scanner and logging correctly.
You will need to setup the tune for injectors, MAP sensor, change resolutions to the tables for fuel and spark, change PE and Spark, IMO put car in MAF only and get idle fueling and BRAF complete and then work on off idle and part throttle, then complete WOT.
We can help but you must get proper parts and data secured so we all don't chase our tails over crappy parts and data.
Remember- Crap data in is crap data out
