Results 1 to 7 of 7
Thread: 2018 dodge challanger unlocked ecm
    May 2017
    21
    I'm having an engine check light on after installing the new ecm I cleared the ecm dtc before you start tuning anything. but now everytime I do a tune and write it I get an engine check light that wont clear.
    May 2017
    21
    0x7E8: P0108 - Manifold Absolute Pressure/BARO Sensor High (Permanent)
    0x7E8: P0123 - Throttle/Pedal Position Sensor A Circuit High (Permanent)
    0x7E8: P0198 - Engine Oil Temperature Sensor Circuit High (Permanent)
    0x7E8: P0222 - Throttle/Pedal Position Sensor/Switch B Circuit Low (Permanent)
    0x7E8: P2122 (Permanent)
    0x7E8: P2127 (Permanent)
    0x7E8: U0402 - Invalid Data Received From Transmission Control Module (Permanent)
    0x7E9: P1DD2 (Permanent)
    0x7E9: P1DF3 (Permanent)
    0x7E9: U0100 - Lost Communication With ECM/PCM A (Permanent)
    0x7E9: U11E4 (Permanent)
    Mar 2018
    Illinois
    873
    Permanent codes have to be cleared by the PCM. Basically it has to see certain conditions and then it will clearout the DTCs. On my 2015, I always get a permanent ABS code but it clears after driving the car.
    BTW the Tuning School (Section B.600 Pg. 53) states in their course workbook that 2018+ PCMs do not need to be sent in for modification and that just the HP tuners bypass cable is needed. Not sure if this a typo as you state you have an unlocked PCM.
    Mar 2008
    Paris, France
    435
    check your ecm connection. unplug and replug.
    http://www.lsxcalibration.com - Lsx Tuning France - Spécialisé Reprogrammation moteur Corvette Camaro Hummer, Ford Mustang et autres véhicules US
    Check our Facebook page http://www.facebook.com/lsxcalibration.com
    May 2008
    Austin, TX
    60
    I'm having essentially the exact same DTCs after reinstalling my unlocked ecm on my 2016 challenger. Did you get this fixed?
    2002 Silverado extended cab 5.3L.
    Volant cold air intake
    Gibson cat-back exhaust
    Electric fan conversion
    2016 Dodge Challenger SXT 3.6L
    Hellcat airbox
    Ported throttlebody
    Pedal Commander
    822
    Are you following the instructions about ignition off, waiting 10 sec, ignition on and then clicking ok after a write?
    I had an engine light if I didn't follow this process when flashing the trans.
    Haven't tuned the pcm yet.
    May 2008
    Austin, TX
    60
    This was before I made any changes to the tune. Just plugged in the unlocked ecm and got those codes.
    I believe the problem worked itself out, in case anyone else runs across this. I'm not sure what did it exactly. I tried unplugging and reconnecting the connectors and driving the car around. When I started it back up, no more DTCs.
    Hellcat airbox
    Ported throttlebody
    Pedal Commander
