Results 1 to 20 of 20
Thread: Timing calculator
    Jul 2012
    32
    Timing calculator
    Im looking for the link to the timing calculator that suits HP. It looks like all the old links have been taken down?? cheers
    Here ya go.
    09 Cobalt SS - E47+EFR6758 =
    07 Silverado ECSB LBZ Duramax - Bunches of goodies
    Jun 2017
    9
    Where is the timing calculator for an LML? The calculator here and posted other places does not include a tab for LML.
    I've never seen a lml calculator for hptuners. I have one for a lml with efilive, but it won't work for hptuners.
    Jun 2017
    9
    Hmmmm, do you have a link for the efilive one? I wonder if I could input the data into efilive and somehow pull it out/ translate it to HPtuners.
    Nvmd I found it. I think. Josh H's calculator?
    Jun 2017
    9
    ok, from what I can see the two axis in the spreadsheet are swapped from the tables in hptuners, but if I was to swap them in the spreadsheet would it still give me the proper calculations? obviously I would have to change all of the tables in the spreadsheet.
    Dec 2008
    Nevada
    4,452
    the inverted table likely has equations pulling or writing to it so it would be better to figure out if its a write to table or a calculate from table.
    it would be better to make a second table that if you write to the original just corrects the cell alignment due to inverted axis.
    if it writes from then you modify the cells by making a new table and setting the existing tables locations to match the new hpt inverted table.
    this way you keep all of the equations linked properly.
    May 2017
    10
    what tables are you using in hp for the calculator? I can't seem to find or match any tables up from the old write ups on how to use the timing calculators with hp
    Jun 2017
    9
    Im using: injector pulse width, pilot off timing, base fuel pressure mode 0, which all work fine except the axis being flipped, then I ran into a problem. One of the tables it uses in EFILIVE is main injection, low alt, mode 0. We have that table in HP but its not using the same variables of calculation as EFI. the main injection table in EFI seems to have RPM vs FUEL QUANTITY, where as HP's main injection table uses RPM vs TORQUE. I could be looking at the wrong table but thats the dead end i have run into for the moment.
    Feb 2017
    Billings,MT
    97
    Could someone please go thru the steps of how to work this calculator again? I've been trying to tune an 06 LBZ and just can't seem to make it work. And I've also had a hard time trying to figure out which tables that I'm actually supposed to be using and where!!
    Thank you
    Not sure if this still works with current HPT software, but this was how it was done back then. Just follow my link.
    https://forum.hptuners.com/showthrea...776#post544776
    I've never upgraded, so I still can do it. Even have one license left.
    Tuner apex2112's Avatar
    May 2007
    Davie,FL
    55
    Here is a copy of the HP Tuner version of the timing calculator.
    Copy of timingV2_HPTConversion.xls
    Feb 2017
    Billings,MT
    97
    Quote Originally Posted by heavyevans View Post
    This is the one that I got confused by. I couldn't find the right tables
    Maybe this will help. Attachment 89370
    This is the one I used that was created by mecanicman. It is different from ones previously posted. Search for his posts, the pics are gone but he did answer several questions.
    Feb 2017
    Billings,MT
    97
    I can't get this link to work.
    Quote Originally Posted by XxScottxXN View Post
    Here it is again. I could be mistaken about it being different from all the ones previously posted. I believe it is only different from a few.
    Feb 2017
    Billings,MT
    97
    Thank you very much! Could you please look at this final tune and tell me if it looks OK? Opinions are greatly appreciated!!
    Feb 2017
    Billings,MT
    97
    Could someone please tell me if this tune is ok to use!!!
    Thank you
    Apr 2019
    6
    ok I tried the calculator for my lb7.... current timing says 100% and the copy past timing table is coming up almost all zeros a few negatives on the low end??? Not sure what I did wrong.
    Jul 2019
    Florida
    110
    Was wondering when you tune injection split do you split it up 45/55
    45/ pilot 1
    /55 pilot 2
    I am running a 6.7 powerstroke it?s very similar to a LML I believe
