Results 1 to 7 of 7
Thread: Incomplete zones??
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    471
    Incomplete zones??
    I did not want to hijack a thread so i will post here. Not sure what the error is telling me. From what it looks like my rows and columns match but it is giving me a zone error i have never seen. I think it is telling me that there is some kind of mismatch since it says it is not supported?
    Ive tried changing the column and row axis in the editor and the only one that does not give me the error is when both are set to the first option.
    What am i missing?
    I have tried different combinations with no success. Do i need to re-scan or something. I set the row and columns, saved it, loaded into the PCM, did a short idle log to get the idle error, tried to copy/paste error and this is what i get
    Thanks.
    I always tune VVE....
    2016 C7 M7 Z51
    Callies ultra billet crank
    Callies ultra billet rods
    Diamond pistons
    Jhonson high speed lifters
    Ported and polished headwork
    Custom cam
    YSi-V7
    Feb 2012
    Houston, TX
    471
    Ok so I started all over. I took my good running MAF tune and made the changes to a 3 bar setup, saved it, loaded it(write entire), started it up and ran a short idle scan. Copied the readings from the scanner, copy, paste % and same thing.I am 100% sure that it is a 1 to 1 except for disabling the MAF and re enabling my dynamic airflow.....
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    Feb 2012
    Houston, TX
    471
    Anybody??
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    Feb 2012
    Houston, TX
    471
    Thanks!!
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    So your columns and row match in the editor and scanner? It looks like you are trying to paste in data from a log that has different parameters.
    Feb 2012
    Houston, TX
    471
    Quote Originally Posted by Jeff7577 View Post
    They are exactly the same. When I go from standard to either 2 or 3 BAR, I copy the labels to match and get the pop up error. The log is from the error hist. It does not show it in my previous posts but I will post a pic of where I am pulling it from when I get home.
    Or maybe even do a video.
    2016 C7 M7 Z51
    Diamond pistons
    Custom cam
    YSi-V7
    Tuner in Training clshortt1's Avatar
    Mar 2019
    Edmond, Oklahoma
    49
    Maybe just copy the cell contents and not the labels. You may be getting the error because your trying to copy and past the axis labels as well as the cell contents.
