Thread: S10 LS Swap, AC control?
    Potential Tuner LT1coupe's Avatar
    Nov 2018
    8
    I swapped an LQ9 complete into an S10 & I'm not getting a grounding signal out of the computer to run the compressor.
    Idea's?
    I have the low pressure switch bypassed
    2001 S10 Xtended cab LQ9, Elgin 1839P cam, T56, Camaro brakes, 8.8 axle, 3.73 gears
    Nov 2018
    8
    I have verified power from the switch to the computer & a ground signal from the low pressure switch to the computer, still no ground from the computer to fire the relay
    Nov 2018
    8
    OK, I have a code P0480 and a cooling fan relay clicking in & out.
    Also have a code P0530
    Nov 2018
    8
    I realize I'm talking to myself, but I swapped to a different PC & the problem is gone, but a new one popped up.
    one of the cooling fans runs constantly now.....
    Any Idea's?
