Results 1 to 14 of 14
Thread: Toyota Tacoma VE Table?
    Mar 2019
    47
    I'm curious to know if there is a potentially undefined VE table? I'm observing a truck running the stock air box/MAF housing showing rather large error in WBO2 vs PE EQ/commanded values at higher load/rpm leading me to believe a VE error is present due to much higher than stock boost this truck is running.
    There are tables i have yet to add to the editor that are used in the load calculation.
    I count sheep in hex...
    Mar 2019
    47
    Quote Originally Posted by Chris@HPTuners View Post
    Thanks for taking a moment to reply! I'll be looking forward to those additions. Please advise when a new VCM Suite is available with the updates. Appreciate the continued support.
    Mar 2019
    12
    Possibly if you have higher than stock boost it's over-running the MAF. Potentially modify the MAF tube and re-scale the MAF transfer function 41x1 to suit.
    Mar 2019
    47
    Quote Originally Posted by Merryfrankster View Post
    We're still under the MAF limit, though close. The problem I'm seeing is that the ECU isn't able to match the PE EQ commanded values, and under high load is off significantly. 11.3 commanded, ~13.0 observed.
    Even on my personal truck which just has a Y-pipe + exhaust, I'm seeing a ~1.0-1.5 AFR discrepancy.
    Both vehicles running stock airbox.
    Mar 2019
    32
    Did you get this sorted JustDSM?
    Mar 2019
    47
    Quote Originally Posted by tune2mbt View Post
    Not yet. I still have the ticket in with HPT to get these defined in the VCM Editor.
    Mar 2019
    12
    That's interesting.
    Apr 2019
    PHX
    9
    Hi Chris.
    Any word on these tables? They’d surely be a big help with an overboosted truck I’m working on.
    Thank you,
    Jake
    Mar 2019
    47
    Any progress or updates on these Chris? We?ve got a few folks having some issues around 3.5 g/rev where trucks are drifting far leaner than commanded (Air Load falling from ~150 to ~120) despite measured airflow continuing to rise.
    Seems like right around 3.5 g/rev and 4500-5000rpm the calibration could use some correction to Air Load values.
    Thanks!
    Mar 2019
    47
    Quote Originally Posted by JustDSM View Post
    Thanks!
    Up.
    They are on my to do list, no ETA sorry
    Mar 2019
    47
    Thanks for the update Chris. Appreciate you doing this.
    Nov 2018
    9
    When will there be support for the 2018 toyota tacoma 3.5l really getting a lot of requests for this truck.
