In the VCM Suite Online Help for reading the VCM, it says "Put the key in the ignition and turn to the ON position (do not start the vehicle)." "Make sure the doors are closed and accessories are turned off (do not lock or unlock the doors during reading or writing procedures or operate any vehicle accessories)" In my vehicle, a 2008 Corvette, which uses the presence of a key fob and simultaneously stepping on the brake pedal and pushing a button, there is no Ignition ON position. I can only either start the engine, or turn on Accessory Mode. So, with this vehicle, what is the sequence of steps I should follow in order to both read the VCM and also to subsequently write to the VCM?
