Results 1 to 7 of 7
Thread: Odd o2 issue 2011 Mustang GT
    Aug 2006
    Arizona
    244
    Ive done many Coyotes and this is the first time I have see anything like this.
    Modifications:
    2011 Coyote Mustang
    D1SC Procharger with 3.6 pulley
    JBA LTs no cats
    ID1050x
    VMP BAP
    I have checked for the following.
    Vacuum leaks- None
    Exhaust leaks- None
    Cam angle operation
    New Motorcraft Upstream o2s
    No o2 extension harness is being used*
    Headers are JBA LTs no cats
    The o2s will read fine for a few minutes. The all of a sudden, both o2s go completely opposite of each other, and the engine obviously runs like crap.
    When I tune it in open loop, the car runs perfect, and the o2s then read perfect all the time, which really confuses me.
    However, I need this car to be able run in closed loop in order for it to learn alcohol composition. It will not learn in open loop obviously.
    Anyone every run into this?
    I have attached a log of what the o2s are doing.
    Any help is appreciated. Thank you
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Dec 2017
    14
    Reverse the wiring
    Dec 2017
    14
    You might have bank 1 on bank 2
    Aug 2006
    Arizona
    244
    Thank you for your response, but I also checked that and both o2 connectors are on the correct sides. I forgot to list that.
    Aug 2006
    Arizona
    244
    Should I just run it off one o2 sensor?
    Senior Tuner CCS86's Avatar
    Nov 2017
    Austin
    1,089
    Don't do that.
    Oct 2016
    Poland
    1,743
    Quote Originally Posted by STAGEUP View Post
    You can for single turbo application for example but I would not recommend doing this in your setup.
