Results 1 to 17 of 17
Thread: Idle tuning
    Idle tuning
    Any help with tuning idle for long tubes? Having issues finding good reads
    Dec 2018
    3
    Long tubes shouldnt have thrown your idle off, sure u dont have a leak?
    Tuner Camaro6's Avatar
    Jun 2018
    Chicagoland
    135
    They will throw you off based on a wideband readings since they are downstream further. You need to adjust the o2 sensor data, but honestly most don't and just leave it. Otherwise, yes you have a leak an unmetered air situation happening.
    2018 Camaro SS, LT4 Fuel System, LT4 S/C
    2020 Ford Edge ST (93-E85 flex fuel tune)
    1999 Pontiac Firehawk
    1987 Chevy Caprice, 6.0L TT 4L80 AWD
    ***Only AWD box chevy in the world***
    Next Level Tuning and Performance
    Tuning email: [email protected]
    I?ve read the long thread about the o2 adjustments but I haven?t been able to tell what was improving what or not. When reading thread, the middle pages, it looked like a bunch of people trying different things and then nothing.
    I went through everything and sealed it with copper rtv. It?s def sealed up now. It?s just not sounding as clean as it did stock. There?s def a cough in there at a hot idle
    Let?s start with where the trims should be while idling?
    May 2003
    South FL
    1,371
    What is your hot idle spark advance?
    [email protected]
    Owner/GM Calibrator
    Scanner showing 16 at 0.4 and 14 at 0.8 kpa
    May 2003
    South FL
    1,371
    Have any logs?
    [email protected]
    Owner/GM Calibrator
    Tuner 5ft24's Avatar
    Mar 2018
    Sedro Woolley, Washington
    110
    Quote Originally Posted by nicul15 View Post
    On the headers? That could be an issue. the Silicon in RTV will destroy O2 sensors in a heartbeat...
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    FIC1000 shorty Injectors
    DW300C Fuel pump
    UPP GTO Auxiliary fuel system
    BoostDistrict LSA Conversion
    BTR Stage 3 PDS Torque cam and kit
    Kooks Longtube headers with High Flow Cat mids
    BoostDistrict LSA CAI with LS7 MAF module
    Mickey Mouse Catch Can
    Hinson 1/2" lowered Engine Mounts
    Magnaflow 3" Cat Back Competition Exhaust
    PLX DM-6 Wideband
    Turbo Technologies Full Flex fuel Tune
    All downstream
    Aug 2014
    Central, LA
    737
    Did you remove your spark plugs during the header install?
    Quote Originally Posted by sevinn View Post
    Yes, and just put in new plugs and wires last Saturday for Unrelated reasons...just because of mileage. Cars running very strong just not as clean as it was stock at idle. Nit picking for sure, but there?s room for improvement, this is why we?re here right?
    Aug 2014
    Central, LA
    737
    Absolutely, I was just curious because I get alot of cars that come by that have a little idle stumble because they cracked a porcelain is all.
    I hear ya. I pull the plugs but know a lot of people don?t and then go nuts diagnosing issues after install.
    Appreciate the help. I did open the gap from .040 to .045 on a oem plug tho. Didn?t notice much change. Maybe gets me a hp or two
    Fixed the idle issue by finding some gen iv o2 calibration posts.
    All my trims are -1 even in idle cells while moving but go +5 while actually idling. What can be adjusted to fix this? I am assuming I shouldn?t leave it like that?
    Mar 2018
    110
    Fuel trims of +- 5 are nothing. As fuel ethanol content varies, o2 sensors age, it will move around a bit
    2006 Pontiac GTO
    M6
    Flex Fuel enabled
    DW300C Fuel pump
    PLX DM-6 Wideband
    Jun 2018
    Chicagoland
    135
    Base airflow matching actual airflow numbers and if you have CAI or IAT breakout, the bias data can get you dialed in real nice :-)
