Any help with tuning idle for long tubes? Having issues finding good reads
Long tubes shouldnt have thrown your idle off, sure u dont have a leak?
They will throw you off based on a wideband readings since they are downstream further. You need to adjust the o2 sensor data, but honestly most don't and just leave it. Otherwise, yes you have a leak an unmetered air situation happening.
2018 Camaro SS, LT4 Fuel System, LT4 S/C2020 Ford Edge ST1999 Pontiac Firehawk1987 Chevy Caprice, 6.0L TT 4L80 AWD
***Only AWD box chevy in the world***Next Level Tuning and PerformanceTuning email: [email protected]
I?ve read the long thread about the o2 adjustments but I haven?t been able to tell what was improving what or not. When reading thread, the middle pages, it looked like a bunch of people trying different things and then nothing.
I went through everything and sealed it with copper rtv. It?s def sealed up now. It?s just not sounding as clean as it did stock. There?s def a cough in there at a hot idle
Let?s start with where the trims should be while idling?
What is your hot idle spark advance?
Have any logs?
2006 Pontiac GTO
M6
Flex Fuel enabled
FIC1000 shorty Injectors
DW300C Fuel pump
UPP GTO Auxiliary fuel system
BoostDistrict LSA Conversion
BTR Stage 3 PDS Torque cam and kit
Kooks Longtube headers with High Flow Cat mids
BoostDistrict LSA CAI with LS7 MAF module
Mickey Mouse Catch Can
Hinson 1/2" lowered Engine Mounts
Magnaflow 3" Cat Back Competition Exhaust
PLX DM-6 Wideband
Turbo Technologies Full Flex fuel Tune
All downstream
Did you remove your spark plugs during the header install?
I hear ya. I pull the plugs but know a lot of people don?t and then go nuts diagnosing issues after install.
Appreciate the help. I did open the gap from .040 to .045 on a oem plug tho. Didn?t notice much change. Maybe gets me a hp or two
Fuel trims of +- 5 are nothing. As fuel ethanol content varies, o2 sensors age, it will move around a bit
2006 Pontiac GTO
M6
Flex Fuel enabled
DW300C Fuel pump
PLX DM-6 Wideband
