Results 1 to 6 of 6
Thread: Anyone have a working E38/6L80/90 T43 bench harness?
    405
    2,326
    I have a working E38/T42 harness I'm trying to add the T43 connector to it and am having trouble getting it to communicate with a T43 that is out of the transmission. There are two CAN+ and CAN- wires and one each CAN+ (120 ohm) and CAN- (120 ohm) wires. I have both CAN+ tied together and both CAN- tied together spliced into the harness and both CAN + and - (120 ohm) wires not connected to anything. Not sure what to do with all the T43 CAN wires. T42 only had one each CAN+ and CAN-.
    Jun 2010
    293
    what year.? didnt noticed CAN 120ohm wires before.
    405
    2,326
    The year shouldn't matter on a bench harness. There are only 4 different Valve Assm/TCMs. One for 07, one for 08-09, one for 10-11, and one for 12-18. They all use the same plug.
    405
    2,326
    Tuner Doubledip's Avatar
    Apr 2007
    Sydney, Australia
    161
    Quote Originally Posted by 2xLS1 View Post
    not sure what you are doing or where you purchased the T42 bench harness but they are wired the same way a T42 and a T43..
    they both have 2 pairs of can wires... 1 set is can in and one set is can out...
    there is no need to run a 120 ohm resistor... the ECU works as a terminating resistor which is enough
    they are wired like this OBD2 plug ---> T43/T42 in ca
    as for 4 6L80/90 T43's... only ever found 2........ 07-->09 and 10 --> onwards
    Ultimate Conversion Wiring
    405
    2,326
    I didn't purchase my E38/T42 bench harness.I built it myself. Used EFILive's bench harness pdf for the T42 CAN pins. It only listed the 2 needed. The pdf file doesn't have the T43 in it. Then in the pin out in post #1 which 2 pairs are CAN in? Which pairs are CAN out? The SD in post 4 shows all 4 as bidirectional. Since I started the thread I've learned more about the wiring and will get it sorted out. While there may only be 2 actual T43's, when buying them as part of the solonoid assembly there are 4 different part numbers. And per my very able dealer parts guy:
    07 - 24275871
    08-09 - 24275872
    10-11 - 24275874
    12-18 - 24275873
