I didnt turn on my vehicle, I just put it in the RUN position.
Turned on my AEM and started logging.
The AFR was jumping all around from 10-19afr!
Is this normal? I thought it would be reading 14.7:1
at startup your in open loop, but in reality your not commanding anything because you havent started the car, start the car to see what your actually commanding.why the heck am I commanding a 10?
noIs that because of me scaling the MAF?
you have an 02 v6 camaro which means you have etc, perfectly normal.and TPS says 16%
Is this normal on pre-startup?
