Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Timing and injector split on a 6.7
    Quote Originally Posted by Jeffrey Kavney View Post
    I understand the relationship and economy vs performance I see stock they have a 50 in the 1st column in pilot injection if I set them from 50 to 40 will I have to set the 60 on my pilot 2 or just put 40 in 1st column in both pilot 1&2
    I'm not sure exactly what numbers you are referring to. Could you post a screenshot of the columns you're referring to?
    Jun 2018
    Albuquerque New Mexico
    264
    Jeffrey you're confusing the pilot's with the main injection. The Pilot injection is not part of the split unless the calculator you're using adds it to which i'd say that's confusing you. Most of the time you only care about the main because we always know Pilots are just that, they are before our main. So Say we have a 45/55 split that's referring to the main injection we know if the main is splitting before and after TDC the pilot will be 100% BTDC. I'm a firm believer in using a timing calc as a point of reference only.
    Jul 2019
    Florida
    116
    I must be really confused if I add timing and fuel to the map how will i know how much is before TDC and what’s BEFORE AND AFTER I DONT KNOW IF IT IS THE VGT TURBO BUT I ADDED FUEL IN PILOT 1&2 and lambda to .30 I can’t get a puff I am not happy with my tuning If I knew where my stock file was I would just buy a tune Waiste of time
    Jul 2019
    Florida
    116
    I’ll post it it’s the .50 1st column pilot 1 mode 0-3
