Results 1 to 10 of 10
Thread: cant read ngc3
    Apr 2019
    6
    cant read ngc3
    for the last week to read from a 2004 dodge dakota 3.7 (ngc3) i have tried it both in the vehicle and on the bench with no luck. when i read from the ECM i get a timeout failure and when i read from the TCM it saves the file but will not open it. attached are screenshots of the errors i am getting. i have allredy contacted customer support and they have not been able to resolve the issue yet. i am not concerned about the TCM but i really need acess the ECM.Capture.PNGCapture1.PNG
    Nov 2018
    Middleburg PA
    13
    Any update of this? I have a similar issue with a 2004 Ram. Doing the same thing
    Aug 2020
    3
    That is odd. I have a 2009 Dodge with a NGC4 and it reads fine after I realized it could only read it with key on engine off lol. Hope HPTuners is eventually able to help but I personally have no ideas
    Feb 2006
    PAC NWest
    396
    Old post, I know. But...
    Some of the NGC3s are not supported. Are you sure yours is?
    When I switched to a NGC4 I still had trouble reading. But I found that disconnecting the TCM while reading and writing did the trick.
    Have you tried selecting the TCM in the second dropdown?
    Mar 2021
    13
    hi friends
    is possible read this NGC3 on bench ? i have same trouble hptuner not recognise my ngc3 from 300C year 2005
    thanks
    Feb 2006
    PAC NWest
    396
    That will only work if your NGC3 is supported.
    Some of the NGC3s are not supported. And it sounds like yours isn't.
    Mar 2021
    13
    Quote Originally Posted by gottogo View Post
    thank for your help
    so i must test with ktag opening this ecu
    anybody have experience to open ngc3 ?
    Feb 2006
    PAC NWest
    396
    Sorry, never could get mine to read.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,264
    Yes you can read these ecm's via bench harness, its the primary way we do our reads(via bench harness).
    Nov 2018
    Middleburg PA
    13
    Hey bill so all ngc3 can be read by bench and are supported? I still can’t get my ngc3 for my 2004 ram to read the ecm. The trans reads fine. I’m think about swapping to an 05 computer now. Reason for this is the build date
