Also no advantages to E85 unless your running some big Compression and can't get your kr down with pump 93 without taking timing out.
Cam for CR, or CR for cam your running. These engines like a lot of timing. I run 22 - 23 wot
Thank you Speed39 - I am running twin turbos on this 392. and now waiting for my forged pistons and cam
This is totally false. E85 will provide gains, even in a mild compression setup. I have a customer that we did a back-to-back test between pump e85 and Renegade 120NOS and the pump e85 was 3 mph faster in the 1/8th mile. This is a truck that runs bottom 7s in and is a 6.0 with LS3 heads and about 9.8:1 compression. 28 degrees of timing is what it liked in both cases.
