Check out the attached log, some knock retard at first fire up, during initial cold launch, and then a quick blip of 2nd gear showing 8* of knock retard. Working with a bunch of folks to determine if its a noisy 2618 piston problem, too much boost for 93 octane, etc etc. Have spent over a week checking all possible hitting of exhaust, etc etc and have not identified anything to cause false knock
Build specs:
426 stroker (6.4L based), 9.5:1 compression
thitek heads (2.20 intake)
4.5L Whipple (5" upper, 10% lower), large oval TB
kooks 2" primary headers, catless, corsa sport cat back
Paramount Super Pro Nag1, 2800 stall
Stock getrag 3.06 rear, dss axles, dss 4" driveshaft
Motor has under 100miles on it since first fire up, running on 93 octane.
Startup Tune 6.hpt
WOT Startup Tune 6.hpl
Startup Tune 6 Log 1.hpl
