Thread: AFR error not registering on graph
    Apr 2019
    13
    I have set up my wide band through the egr and it is working as it should, showing on the chart vs time. I have tried to set up a graph for egr error and the it is bouncing around the cells as though it is set up right but it does not record any data. I will attach pics of all the settings and math I have done. I have watched numerous videos on this and believe I am doing it right. Can some one see where I have made a mistake?afr err.PNG
    Feb 2019
    32
    Quote Originally Posted by hbunker View Post
    same here
    Dec 2011
    Amarillo, TX
    299
    Using O2 sensor voltage isn't correct, not even sure why that's in there at all.
    AFR Error should be as follows: 100 * ([AFR actual] - [commanded AFR]) / [commanded AFR]
    So you should be using the AFR through EQR in place of AFR actual, then need to be logging the commanded AFR channel in the scanner.
    JTC Performance - Authorized HP Tuners Reseller
    Performance Tuning in the Texas Panhandle
    Aug 2019
    4
    Same problem here. I see charcaol03silvy's point but after changing my formula to what was listed Im still not seeing any numbers in the highlighted cells. Anyone have a fix?
