Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: adjusting stoic afr table to accomodate 10% E
    Feb 2018
    824
    I was toying around with the fact of changing the 0% column to around 14.4 to account for the 10% ethanol in pump gas. I'm not going to be running any type of flex fuel so is this necessary? I mean it's only a 2% difference (14.7-14.4/14.7), but i'm ocd when it comes to my tune
    13,565
    Never bothered, won't make a lick of difference if you ask me.
    Feb 2018
    824
    Won't that somewhat effect WOT considering you are in OL and the EQ ratio is based off of that stoic number?
    Aug 2009
    Calibrating
    3,373
    I always set stoich to around 14.2 most times leaving it at 14.68 already throws it off about half a point
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Apr 2016
    331
    Do you have a virtual flex fuel adjustment in the cal? If so, it will adjust. If not, it wouldn’t hurt to change it. I have the actual alcohol sensor installed/activated and at 10% it commands 14.1. I’ve changed the commanded afr on my older vehicles(non flex fuel) to 14.1, though they are completely stock. Probably doesn’t matter, but, OCD I guess.
    13,565
    Fuel here is never really 10%, it always varies a little bit so I don't even bother changing it. Haven't run into a single issue with trims or WOT fueling when leaving it around 14.6-14.7 running ~E10.
    Feb 2018
    824
    Quote Originally Posted by NotSure View Post
    No i do not have a FF sensor in it. That's why I'm asking because I know that it won't adjust based on the E content
    Feb 2018
    824
    But if I'm running a stoic ratio of 14.68 that means that if i want an 11.5 afr the eq ratio will need to be 1.276. Now if i keep that same eq ratio but there is 10% E in the gas then it would be 14.2/1.276=11.1 afr......so it's almost a half of a point difference. Seems like a pretty big difference to me
    Feb 2018
    824
    cool, maybe i'll just leave mine be
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by sgod1100 View Post
    It’s exactly half a point...
    14 Gen 5 Viper
    I think he means the PE afr..
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by Scottgt21 View Post
    That too since PE is Just a multiplier anyways
    14 Gen 5 Viper
    Feb 2018
    824
    right, so if i'm commanding an 11.5 and my commanded matches my actual i really could be at 11.1 with 10% E if my stoic is at 14.68 correct?
    Aug 2009
    Calibrating
    3,373
    No...if stoich is 14.68 you would be at 11.5
    Set stoich correct, always...
    Forget AFR, learn lambda and look at commanded lambda
    14 Gen 5 Viper
    Feb 2018
    824
    Quote Originally Posted by Ben Charles View Post
    ok, but isn't commanded lambda a function of what your stoic is set to?
    Yes it is. 10% E is 14.13. It's best to set the stoic table and leave it. It really comes into play when changing the timing based on E content then it can go bad fast if not reported right to the ECU.
    Feb 2018
    824
    Quote Originally Posted by asteggall View Post
    agreed, but my car doesn't have a flex fuel sensor from the factory (2014 ctsv) so that is why i was asking about changing that stoic number to something like 14.4 (in the middle of 0 and 10% E) or just leave it the way it is from the factory which is 14.68.
    Apr 2016
    331
    Change it. If the fuel in your area is consistently e10 then adjust the afr to that, if the fuel varies in your area or travels then maybe split the difference. But I don’t know if you can even get pure gas at your average pump anymore. I have to go out of my way to buy “rec” gas (recreational, and no alcohol) to put in small engines like the mower, generator, etc to help to avoid storage issues.
    Feb 2018
    824
    gotcha, I think i will. thanks for everyone's input
    set the stoich table to 14.2 and leave it.... then adjust the other tables for PE ratio accordingly...
    06MonteSS
    2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, Custom paint-matched Bowtie emblems, Custom painted SS emblems, BMR strut tower brace, CAI - Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Bo White Ported/Polished throttle body, Custom DiabLew Tune
