Hi, I ran into an issue where under higher boost and WOT, the 2-3 shift would bang off the rev limiter at 6600 rpm and feel like its in neutral. I turned the boost down and it didnt have that issue however its shifting at 6600rpm which is basically on the limiter. My tune shows it should be shifting at 6200, i knocked it down to 5800 and no change. I then reviewed the "WOT Shift speed - Normal" and found it should be shifting from 2-3 at 85mph but when i test it, its switching from current gear 2 to 3 at about 6550rpm and 101mph. My 1-2 shift is early also. I did a log of a 1-2-3 WOT pull on 10psi to illustrate whats going on. Combo is a turbo 5.3, stock rebuilt 4l80e with hd2 kit, circle d triple disc converter, 3.55 gears, 28x10.5 tire. Attached are the log and the tune, please review if you have the time. Thank you!
