Results 1 to 7 of 7
Thread: Spark plugs recommendation
    Jan 2019
    Bulgaria
    19
    Hi guys,
    My 2012 Dodge Charger SRT8, 6.4L is literally melting my spark plugs one by one. There were Desnso ITV20 in it. I will try with ITV 22 now.
    But can you tell what plugs to use and to be sure they won't be melt when I push the engine a bit
    Mar 2018
    Illinois
    873
    Woah, you should not be melting plugs...period. If you are truly seeing indications that the plugs are melting then the motor is running dangerously lean. Iridium plugs have the best resistance to melting. Are you running any power adders...supercharger...cam..etc? Check your intake manifold bolts for proper torque as on challengers this is a common source of leaks.
    Nov 2017
    816
    What fuel are you running on?
    Jan 2019
    Bulgaria
    19
    I have a procharger kit. We are making changes to the software here.(I can attach a file later,if needed)
    The fuel is petrol 95
    Mar 2018
    Illinois
    873
    That is what I suspected. Are you running a wideband and have you confirmed fueling is within safe limits? Normally on boosted applications you want to run 1 to 2 heat ranges colder on the plug. If you are not running forged pistons, be conservative with the tune and don't run too much boost. 6.4L are known to bust piston landings with ease.
    Jan 2019
    Bulgaria
    19
    We are equipped with AEM wideband sensor and water/methanol injection, but I'm not sure about the pistons
    Jan 2021
    Miami
    351
    so what plugs are recommended?
    By the prickle of my thumb something wicked this way comes!2008 Chrysler 300c! 2013 heads/220/230 comp cam/LTheaders/FTI 2600 stall converter.
