Results 1 to 5 of 5
Thread: Final Airflow Min, 102mm Throttle Body
    Jun 2012
    Tewksbury, MA
    15
    2011 CTSV, has a 102mm TB (china) and 4.5" CAI. Updated the ETC scalar but still getting elevated RPM until the adaptive idle kicks in. I'm trying to set the final airflow minimum like in the BigMike tutorial but the car idles at ~1500rpm and 20% tps regarless of how low I set final airflow min. I even zero'd out the entire table (tune/log attached) and the car still adds air to get to 1500 rpm from somewhere. What am I missing?
    Thanks for looking.
    Mar 2011
    Ripley, MS
    1,865
    Have you tried a TB relearn?
    Exactly, learn the the new throttle body by a GM device.
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,454
    Try setting the etc scalar from 7,400.0000 to 8,000.0000. But why are your base airflow table 0 ? Your proportional and integral are 4,096? All the idle rpm's are 575? I would get the stock numbers back in there (except etc scalar),
    so it will at least run.
    2013 Silverado 5.3, 6L80k 8.8
    Jun 2012
    Tewksbury, MA
    15
    Hi, thanks for the replies. I have those idle numbers in there to disable the adaptives because I was trying to find the final airflow min via this method:
    https://forum.hptuners.com/showthrea...e-tuning-guide
    I put 0 in to airflow min in as a test to show no matter what I do the car will idle at ~12-1500 with adaptives disabled. In general the car idles good with the stock settings but pulls when coming off the gas. Increasing the scalar is a good idea, I will do that when I get the car back. I also plan to try decreasing the %max as a test just to see if I can get the blade to close.
