Results 1 to 6 of 6
Thread: 2016 z06 need computer
    Dec 2016
    21
    So for reasons beyond my control i have a bricked e92 out of a z06. i purchased a new one. to be sure, is there anything different procedure to writing onto the new ecm. i have a good file i just dont feel like having another bricking another one. thanks
    13,533
    Has the new computer been flashed by the dealership first with the VIN?
    That has to be done first, HPT can't write to blank computers.
    Tuner in Training hitmix300's Avatar
    Jun 2015
    detroit
    20
    yeah like five finger said; first get the pcm programmed to the vehicle for pats & bcm communication. you can do this with a gm mdi 2 and 40$ to acdelco for the online licensing. or pay the dealership 100-150. do not use hptuners until the vehicle is in factory state aka run'n'drive.
    2016 GenV 2SS twin turbo @20psi
    Dec 2016
    21
    Thanks guys so then I would be able to access the ecm like always I assume. Would it be best to rewrite all the tunes off the new ecm flash. Or will the old one work after.
    13,533
    Maybe personal preference here but first you will of course have to read and license the new computer after you do what needs to be done. Then I'd take your old tune and just use the compare feature if you want to copy over all the old tune files data into a new tune for the new computer.
    That would be a super quick, couple click method to copy over all the data and then go ahead and flash as you wish.
    Jun 2012
    Canada
    154
    I bricked 1 before. I bet you dollar to donuts if you reflash it with mdi2 wirh gm sps will bring it back to life and save you the hp tuners credit. Always worked for me. I suspect ecu powered off durring the errase process, or you lost connection.
